My show file somehow went blank and now I have to start from scratch. The problem I am running into now is there is no dimmer control options on the RGB matrix which I had before to get the lights to work. Any ideas on how to get this option back or how to get my lights to react to the RGB matrix would be greatly appreciated.
This is a screenshot of what my window looks like. You can see there is no option in the bottom right.
Dimmer control option missing on RGB matrix
- Real Name: Andrew Glaude
I downloaded QLC+ 4.12.2 (25.08.2019) and the toggle for dimmer control is now there.
- Real Name: Steve
Sorry to bump an old thread, but I am trying this feature out for the first time with some of the $30 36W LED par cans... If I activate the matrix and go to simple desk I can see the RGB channel sliders being activated but intensity is left at 0 for all lights. If I manually put intensity to max in simple desk then the RGB Matrix effects work.
I am running v4.12.6 on macOS. My screen looks like your screenshot above, there is no setting for dimmer control.
In general, I keep my intensity levels separate from everything else.
So I have a frame of level sliders on my VC, being able to control the total amount of light on the stage.
Independent of whatever function is running.
That is: IF your fixtures do have an intensity channel - you're good.
If not, you will have to work with submasters and oh boy(!) that is not practical. Now, this would need a Virtual Dimmer channel, which still has to be invented inside QLC+.
- Real Name: Steve
The real question for me is, did the option go away and why? Was it intentional? I do understand your separation of function, so you can move independently of either intensity or colors, it just takes a little more setup work to get going but the payoff is there in the end. Just curious why it went away entirely.
- Real Name: Mischa
First time poster - I am having the same issue. The Dimmer control option is missing when I try and create an RGB Matrix. I on a MacBook Pro Monterey 12.5.1, I updated from QLC+ 4.12.5 to 4.12.6, but this didn't solve the problem. Some of the fixtures in the fixture group have dimmers, some don't. I tried using only fixtures that have a dimmer - still no Dimmer Control button.
Screenshot and .qxw files attached.
Any help much appreciated. Thanks for a great program.
Mischa
Mischa
- No Dimmer Button.qxw
- (17.53 KiB) Downloaded 78 times
I can reply here.
Dimmer conrol has been removed on purpose.
The principle is that QLC+ functions should be specialized in specific functionalities (EFX for movements, RGB Matrix for colors, etc)
However, over time QLC+ users asked for more, so RGB Matrix can control other channels and EFX can control colors...
To me, this is quite inconsistent, even though I appreciate the flexibility. (not even talking about maintaining so many scenarios)
At last, dimmer control had flaws on multiple heads, so I preferred users to create Collections with a Scene raising exactly the dimmer channels needed.
I could restore the option, but I'd prefer to avoid it. For sure it won't be there in QLC+ 5.
- Real Name: Mark Z
Removing this feature is difficult with the Show Manager.
WITH dimmer control, I could add an RGB matrix on one track to control all 12 of my LED bars with an RGB matrix pattern.
WITHOUT dimmer control, I now need two tracks; one with the LED bar RGB matrix pattern, and another extra track with just a silly sequence only to turn on the dimmers of the LED bars
Is there a better way? Otherwise I think the dimmer control should be added back because this makes creating shows more difficult.
