JMS usb2dmx
pengumaniac
Real Name: Manfred Flintstone
yesterday I got contact w new member Corlight (@M. as admin: feel free to read my PN)
we're talking about
he is underdeveloped
on 60 € priceclass quite ok, but:
a) couldn't contact (only tried telephone...)
b) Only Win-version of QLC+ is always fine (AFAIK...)
c) I suggest different charges:
- ones, who can be flashed
- others who can't
my question is right now: how does QLC+ interpret the empty (or simply NULL) S/N on FTDI's
what if toLatin1() returns "\0" as I read somewhere in qt docus...
btw: udev SUBSYSTEM does not need RegEx "*" as wildcard. Sure
review:
viewtopic.php?f=5&t=7340&hilit=jms+usb2dmx
Gentoo | profile=desktop | LXDE | QLC+ qt4-build / openSUSE 13.2-x86_64 | KDE | QLC+ qt5-rpmbuild
The best way to predict the future is to invent it. (Alan Curtis Kay) - I'd like to emerge -avuND world, but there are no news in sync for stable updates
pengumaniac
if we could continue in peace now again, Dear Massimo, I think you're on a good way...
Would you please show me the right place in code, where the SerialNo. should be get from FTDI-Chip into new and reworked v4.10?
pengumaniac
* OSX - sure not me ...
* QLC+_4.10.0-TEST-20150925.exe on WinXP has correct DMX output
* Linux (Gentoo, Kernel v4.2.3 / gcc v4.9.3)
+ the good: qt4 x86 build fine, no more "garbage" in S/N displayed
- but no Output - again only with NULL instead of serial().toLatin1() in
https://github.com/mcallegari/qlcplus/b ... e.cpp#L233
dmesg
Event USB plug in:
[   93.830024] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[   94.016073] usb 2-1: New USB device found, idVendor=0403, idProduct=6001
[   94.016079] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   94.016082] usb 2-1: Product: USB <-> Serial
[   94.016084] usb 2-1: Manufacturer: FTDI
[   94.103972] usbcore: registered new interface driver usbserial
[   94.103996] usbcore: registered new interface driver usbserial_generic
[   94.104015] usbserial: USB Serial support registered for generic
[   94.124884] usbcore: registered new interface driver ftdi_sio
[   94.124911] usbserial: USB Serial support registered for FTDI USB Serial Device
[   94.125007] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[   94.125059] usb 2-1: Detected FT232BM
[   94.128128] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
Event Power plug in "DMX512 Decoder" on DMX-line:
[  254.790059] usb usb2-port1: disabled by hub (EMI?), re-enabling...
[  254.790069] usb 2-1: USB disconnect, device number 2
[  254.790260] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[  254.790275] ftdi_sio 2-1:1.0: device disconnected
[  255.070024] usb 2-1: new full-speed USB device number 3 using uhci_hcd
[  255.256148] usb 2-1: New USB device found, idVendor=0403, idProduct=6001
[  255.256153] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  255.256156] usb 2-1: Product: USB <-> Serial
[  255.256159] usb 2-1: Manufacturer: FTDI
[  255.262202] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[  255.262248] usb 2-1: Detected FT232BM
[  255.264215] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
lsusb
Bus 002 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
qlcplus debug,
a) by serial().toLatin1():
Loaded I/O plugin "DMX USB" from "libdmxusb.so"
static QList<DMXInterface*> LibFTDIInterface::interfaces(QList<DMXInterface*>) DMX USB VID: "403" PID: "6001"
static QList<DMXInterface*> LibFTDIInterface::interfaces(QList<DMXInterface*>) DMX USB serial:  "" name: "USB <-> Serial" vendor: "FTDI"
[setOutputsNumber] base line: 0 outputMap: QHash((0, 0))
[Universe] setOutputPatch - ID: 0 , plugin: "DMX USB" , output: 0
[QLCIOPlugin] setting lines: 0 4294967295 0
virtual bool DMXUSBWidget::open(quint32, bool) Line: 0 , Input mask: 0 , Output Mask: 1
virtual bool LibFTDIInterface::open() "USB <-> Serial" unable to fetch serial number
virtual bool DMXUSBWidget::close(quint32, bool) Line: 0 , Input mask: 0 , Output Mask: 0
virtual bool DMXUSBWidget::close(quint32, bool) All inputs/outputs have been closed. Close FTDI too.
virtual bool LibFTDIInterface::clearRts() "USB <-> Serial" USB device unavailable
virtual void DMXUSB::configure()
void IOPluginCache::slotConfigurationChanged()
[Universe] setOutputPatch - ID: 0 , plugin: "None" , output: 4294967295
virtual IOPluginCache::~IOPluginCache()
b) by NULL:
virtual bool DMXUSBWidget::open(quint32, bool) Interface correctly opened and configured
[QLCIOPlugin] setting lines: 3 4294967295 0
Again good old Patch, to get at least one restive FTDI working...
pengumaniac
should that really mean, wait --- home:mcallegari79 / qlcplus-qt5 on oSL13.2 by "One Click Install"
* install works fine
* output DMX, too - Out of the Box
Congratulations, you got the beast! 8-)
Smove
Dear all,
I have a problem with the JMS USB2DMX Pro converter on Win10. Converter works fine on OSX but on Win10 it seems that no DMX data is send to the controller.
Latest driver for Windows is installed. No errors in Windows Devie Manager. QLC+ Version 4.12.4. Device is recognised and selected as output in the In/Out-Manager.
In other posts I read that the missing serialnumber of the JMS USB2DMX Pro is causing the problem. I tried to reprogramm (enter a serialnumber) the converter with FT_Prog as mentioned in another post but the converter doesn't keep the changes after I klick 'programm'. When I rescan the devices the serial is empty again.
As I can read here there is a patch to get at least one USB2DMX Pro converter working. But unfortunately I don't know how to patch QLC+ with the sourcecode posted here:
https://github.com/mcallegari/qlcplus/c ... 6b68ce7ea2
Any help would be highly appreciated. :)
Thanks in advance,
Smove
