Hi ! I' m new to QLC+ and DMX, I'm using QLC+ 4.13.0 on windows 11 and testing all fuctions at this time. My Lights forks fine with many functions but I found a strange reaction with audio triger : it works fine with voices but don't react with music (???) I see clearly band growing on stectral analyser for voices, but no reaction to music (all sounds cames from the same speaker)... It does not seen to be a microphone problem on the computer ( records works fine on Audacity and other programs). Is there any parameters I missed in QLC ?
T.I.A. for your lights !
Audio triger strange reaction ...
Welcome to the forum,
Change your system audio input preferences—set it to AUX-in or whatever your PC calls it. Set it as the default.
Now, in QLC+, this audio input (the default one) should be available and ready to be used.
- Real Name: Christophe OWCZAREK
Thank for your answer, that was not exactly the solution but it put me in the right way !
I Just fix the problem : I had to deactivate the right to microphone in parameters for many applications (I keept parameters, audacity and QLC+) and now it works !
