when you locate the fixtures and you choose a color in color widget, either in the basic or full tab, the color selection is not applied but I've to manually change one of the rgb values to update it.
Here I've chosen a pure red in the basic tab, you can see that it show the right values in the full tab but it's not applied:
Same issue with the color picker in the fanning selector, here I've selected a red but it still show a pink color:
After moving one value in the rgb channels the color selection is updated:
linux/gnome, the last appimage built on May 3.
ALMOST solved - color and color-picker not applied
file attached
- Aura_000.qxw
- (8.85 KiB) Downloaded 5 times
