First installation
yahav
Real Name: yahav tenne
Hey.
I am quite new to qlc+
I downloaded the image of the installation to a Raspberry Pi.
When I turn on the Raspberry Pi, it asks me for a username and password. I put it in and that's where it stopped.
Can someone please explain to me what I'm doing wrong?
I also tried :sudo service qlcplus start
nothing happened
Thank you
Hi, can you please tell us more about your setup?
Pi model?
Have you tried to change or flash your SD card once again?
yahav
hey
I use a 3b pi
I just downloaded one version back and it works.
u4cigam
Real Name: Iaan Flint
The latest image does not start up on my pi3 like the previous versions used to.
So far all I can see is that the file /etc/init.d/qlcplus is missing and starting the service manually does not work either.
As mentioned in other posts, the new image startup scripts changed.
Please read the updated documentation.
What is the output of the following command?
qlcplus -platform eglfs
