Build QLC+ with Qt 6.7.0
sbenejam
I'm trying to build QLC+ 4 latest sources with Qt 6.7.0 on Ubuntu 22.04 and I get the following error:
[ 52%] Building CXX object engine/test/grandmaster/CMakeFiles/grandmaster_test.dir/grandmaster_test.cpp.o
In file included from /home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/qabstractitemmodel.h:8,
                 from /home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/QtCore:19,
                 from /home/sbenejam/Qt/6.7.0/gcc_64/include/QtTest/QtTestDepends:3,
                 from /home/sbenejam/Qt/6.7.0/gcc_64/include/QtTest/QtTest:3,
                 from /home/sbenejam/qlctest/engine/test/efxfixture/efxfixture_test.cpp:21:
/home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/qhash.h: In instantiation of ‘struct QHashPrivate::Node<unsigned int, FadeChannel>’:
/home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/qhash.h:449:11:   required from ‘struct QHashPrivate::Data<QHashPrivate::Node<unsigned int, FadeChannel> >’
/home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/qhash.h:1257:71:   required from ‘qsizetype QHash<Key, T>::count() const [with Key = unsigned int; T = FadeChannel; qsizetype = long long int]’
/home/sbenejam/qlctest/engine/test/efxfixture/efxfixture_test.cpp:458:5:   required from here
/home/sbenejam/Qt/6.7.0/gcc_64/include/QtCore/qhash.h:76:7: error: ‘QHashPrivate::Node<Key, T>::value’ has incomplete type
   76 |     T value;
In file included from /home/sbenejam/qlctest/engine/test/efxfixture/../mastertimer/mastertimer_stub.h:25,
                 from /home/sbenejam/qlctest/engine/test/efxfixture/efxfixture_test.cpp:28:
/home/sbenejam/qlctest/engine/test/efxfixture/../../src/mastertimer.h:32:7: note: forward declaration of ‘class FadeChannel’
   32 | class FadeChannel;
[ 52%] Linking CXX executable fadechannel_test
[ 52%] Linking CXX executable fixturegroup_test
make[2]: *** [engine/test/efxfixture/CMakeFiles/efxfixture_test.dir/build.make:104: engine/test/efxfixture/CMakeFiles/efxfixture_test.dir/efxfixture_test.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:3416: engine/test/efxfixture/CMakeFiles/efxfixture_test.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 52%] Building CXX object engine/test/function/CMakeFiles/function_test.dir/function_test.cpp.o
[ 52%] Built target fadechannel_test
[ 52%] Linking CXX executable efx_test
[ 52%] Built target fixturegroup_test
[ 53%] Linking CXX executable fixture_test
[ 53%] Built target efx_test
[ 53%] Built target fixture_test
[ 53%] Linking CXX executable grandmaster_test
[ 54%] Linking CXX executable genericfader_test
[ 54%] Built target grandmaster_test
[ 54%] Built target genericfader_test
[ 55%] Linking CXX executable function_test
[ 55%] Built target function_test
make: *** [Makefile:156: all] Error 2
sbenejam@migjorn:~/qlctest/build$
hansjuergen
QLCplus is currently built based on QT 5.14.2: https://github.com/mcallegari/qlcplus/b ... ld.yml#L72
If you are knowledgeable about QT upgrades, feel free to adapt the code to support the needs of QT 6.x, I'd say.
I am not and briefly tried after we ran into a QT 5.14.2 bug, but it requires more knowledge about the meaning of the error messages than I have today.
There are certainly some people who have done such upgrades before, are you one of them?
janosvitok
Real Name: Jano Svitok
The attached patch allows compilation with Qt6.7, but most probably breaks QT5 compilation - must be #Ifdef'ed
qt6.7.diff
(3.69 KiB) Downloaded 31 times
Proper fix upstream
sbenejam
I just build QLC+ 4 with Qt 6.7.0 without errors. Video playback starts without delay. The audio from the video is not played.
Compiled with Qt5 video and audio from the video works. For the video to be played without delay it must be played a couple of times first.
Environment:
Ubuntu 22.04
Qt5 from Ubuntu
Qt 6.7.0 with QT Online Installer
Pipewire 1.0.3 from a Ubuntu PPA
Audio issue should be fixed now upstream
sbenejam
I'll test it later.
sbenejam
Works as expected now. Tested with *.mp4 and *.ogg video test files. One more thing *.ogg files don't appear in Files of type dropdown when you add a video file. You need to show all file types to add it.
sbenejam
After some tests with QLC+ build with Qt6.7.0 on Ubuntu 22.04 it seems to work without delays (tested with 2 laptops).
Maybe now is a good time to add the option to choose the output audio device to play audio from videos, as you can already do with audio functions.
Yes, I think with the switch to Qt6 it could be a nice feature to add
sbenejam
Hi Massimo, I'm testing QLC+ 4.13.1 GIT build with Qt 6.7.0 running on Ubuntu 22.04 with Pipewire 1.0.3. In the I/O Audio tab some inputs and outputs are missing (monitors, mics, etc.). It seems that QAudioInput and QAudioOutput in Qt5 are now called QAudioSource and QAudioSink. Attached you can see QLC+ Audio tab and qpwgraph showing audio devices and inputs/outputs on my system. FOH, Stage and FX are virtual devices that I have configured to route audio to the desired audio output if I need.
sbenejam
I found that QaudioSource and QaudioSink are used in audiorenderer_qt6 files in QLC+ code. Sorry.
sbenejam
It seems that alsa audio devices are not detected or missing. Some non alsa input and monitor are not detected too.
