Just upgraded to 4.13 and the EFX seems to behave rather erratic.
I don't know what's going wrong, it worked on the previous version, even the test version.
I added an video that shows the behavior
[youtube]https://youtu.be/djHaCEVO8t8[/youtube]
Weird efx behaviour QLC+ 4.13
- BremDjenzzen
- Real Name: Bram Janssen
More info please.
Is the EFX relative?
How is it started?
Sample project to reproduce the issue?
How is it started?
- BremDjenzzen
The EFX was relative but seems to have the same strange behavior when relative is turned off. (in a fresh project setting it to non relative fixes it)
The effect was started from the EFX Config menu.
The way of triggering it doesn't seem to matter. if its set to relative then is behaves strange.
I do use a selfmade fixture profile witch i will attach below
- Strange EFX.qxw
- (2.89 KiB) Downloaded 18 times
- Grace-7X40w.qxf
- (11.4 KiB) Downloaded 18 times
If you add a preset for a position, it works ... Relative mode needs some reference to something.
- Strange EFX2.qxw
- (3.73 KiB) Downloaded 16 times
