Hi everybody !
I have OS2L with VDJ setup to have my scenes (in my chaser) beat synced.
The scenes aren't runing at all.
I added functions (a chaser with 2 scenes) in the speed-dial properties (https://www.qlcplus.org/old/docs/html_e ... ddial.html) but somehow, the scenes aren't moving on.
For my test application, I have 2 PARS wich should turn red-blue-red-blue... like the police, beat synced. But someway, they arent doing anything. I added 1 red scene and 1 blue scene to the functions tab.
I also gave a shot for a RGB matrix sequence (flash), it doesn't do anything either.
The beat is well received by the speed-dial-widget in the VC as I see the 'tap' button getting hit.
What did I miss ?
Scene of my chaser wont go on
Put both scenes inside a chaser and have the speed-dial widget set the timing of the chaser.
Please find an example attached.
- flipflop.qxw
- (3.79 KiB) Downloaded 44 times
Thank you, I don't know how you did this, but it's working. I saw, that you added a sequencer to do the job.
But this isn't working as expected : the "beat" captured from VDJ is the "BPM" value. That value doesn't really match the song rythm.
Whould a "audio trigger" with laptop mic be better ? (I saw smothing like that is possible).
And how did you setup your audio widget so you get your hold times out of it?
Audio-widget detects beat -> set a DMX channel -> triggers the tap-button -> sets the pace of the chaser. (I used a Loopback channel for this now ... easy and quickly)
video to illustrate: https://streamable.com/ylbohc
project-file attached.
- flipflop.qxw
- (5.49 KiB) Downloaded 33 times
