Hello. Good morning, I have tried the latest version 4.12.7 and I have noticed that it reproduces x.wav audio files badly. This already happened in some other old version. Can it be solved or does it have to be? Thank you.
NOTE: I am part of an amateur theater group and I regularly use QLC+. We are always tight on money but I will try to make some contribution.
Thanks again
new version 4.12.7 plays wrong .wav files
Hi, can you please share the file?
Also, on which operating system are you running?
- Real Name: Alfonso Garcia
Hi, I'm using windows 10.
It won't let me attach the test.wav file.
What other format supports uncompressed?
Hello.... Clarifications about the problem: When I try to add new audio I only have the option audio type: (.mp3 )
In version 4.12.6 or GIT version 4.12.7.351 I have the options: (.aiff, .aifc, .flac, .oga, .ogg, .wav, .mp3)
I´m ussing Windows 10
Thanks for answering.
Greetings
Greetings
Hi, there's been a deployment issue on Windows.
I fixed it and re-uploaded the installer (4.12.7-1)
Please try it and let me know if the issue is fixed.
Thanks for reporting
I can confirm that with the new installer, the full range of supported audio files now is back again.mcallegari wrote: ↑Mon Jun 12, 2023 3:27 pm Hi, there's been a deployment issue on Windows.
Thx.
Tested, all ok.
Thank you so much.
Thank you so much.
