Crash Windows 10
Laurijn
Real Name: laurijn van den heuvel
hello i have a problem but i cant find the problem what tricker the software to crash
i found in window 10 log system this log about qlc
but i cant find with the help of our best friend Google the problem
i have also try the log version of qlc it self but the file is still empty
i run version 4.12.4
here is the event log of windows about the crash of qlc
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2022-02-02T19:59:10.6016689Z" />
    <EventRecordID>43223</EventRecordID>
    <Correlation />
    <Execution ProcessID="0" ThreadID="0" />
    <Channel>Application</Channel>
    <Computer>DESKTOP-57VOHCJ</Computer>
    <Security />
  </System>
  <EventData>
    <Data>qlcplus.exe</Data>
    <Data>0.0.0.0</Data>
    <Data>60d85b2a</Data>
    <Data>Qt5Core.dll</Data>
    <Data>5.14.2.0</Data>
    <Data>609ea88f</Data>
    <Data>c0000005</Data>
    <Data>0003a9c6</Data>
    <Data>2688</Data>
    <Data>01d816b9bc17441d</Data>
    <Data>C:\QLC+\qlcplus.exe</Data>
    <Data>C:\QLC+\Qt5Core.dll</Data>
    <Data>cf92d5a1-16af-41ed-83a4-4984c338ebf5</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
i hope that some one can help to stabalise qlc again
kind regardz Laurijn
kenact
Real Name: Ken Coughlin
Can you tell us what you were doing when it crashed?
There were reports of some crashes in 4.12.4
Please try latest test version viewtopic.php?f=12&t=3135
Laurijn
The times is different when it crash. Its crash when we use qlc and also crash at Thimes when nobosy use it.
Laurijn
I Will try the New version
Laurijn
i have try the new version en have an another error
Logboeknaam:   Application
Bron:          Application Error
Datum:         18-2-2022 20:03:03
Gebeurtenis-id:1000
Taakcategorie: (100)
Niveau:        Fout
Trefwoorden:   Klassiek
Gebruiker:     n.v.t.
Computer:      DESKTOP-57VOHCJ
Beschrijving:
Naam van toepassing met fout: qlcplus.exe, versie: 0.0.0.0, tijdstempel: 0x61d6fa6f
Naam van module met fout: qlcplusengine.dll, versie: 0.0.0.0, tijdstempel: 0x61d6f767
Uitzonderingscode: 0xc0000005
Foutmarge: 0x000c8ccf
Id van proces met fout: 0x2c1c
Starttijd van toepassing met fout: 0x01d824500d3c0ff4
Pad naar toepassing met fout: C:\QLC+\qlcplus.exe
Pad naar module met fout: C:\QLC+\qlcplusengine.dll
Rapport-id: 3d1a43e7-a269-47b9-8879-8b8ff65553c3
Volledige pakketnaam met fout:
Relatieve toepassings-id van pakket met fout:
Gebeurtenis-XML:
  <System>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2022-02-18T19:03:03.1975301Z" />
    <EventRecordID>51341</EventRecordID>
    <Correlation />
    <Security />
  </System>
  <EventData>
    <Data>61d6fa6f</Data>
    <Data>qlcplusengine.dll</Data>
    <Data>61d6f767</Data>
    <Data>000c8ccf</Data>
    <Data>2c1c</Data>
    <Data>01d824500d3c0ff4</Data>
    <Data>C:\QLC+\qlcplusengine.dll</Data>
    <Data>3d1a43e7-a269-47b9-8879-8b8ff65553c3</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
is it possible that is comes that I have multi rgb matrix whit svg playing
I try to thing out of the box
But now QLC+ starts right?
Does it crash while doing a show?
The log shows that the engine is crashing.
Laurijn
yes this is while i run in show mode
is it possible that it comes by using gif in the rgb matrix
That might be the case. What do you do with the gif? And how big is it?
As people are not aware of the binary size of things no more, sometimes a small looking thing eats up 4Mb in size... And since we are using only some pixels - yes you guessed it right: too much overhead.
Laurijn
i have checked the file size of the gif and those are not bigger then 40kb.
since I have update the software I get now a log file and when it crashed it says
[Universe] HTP check not passed 52 0
I know what htp does but why universe
Laurijn,
I cannot answer to the fault code, but everything runs inside its universe. (look at input-output tab)
kenact
I also had a crash. My operator had just click Next in a chase. It was step 25 in the chase, which is a simple Show cue with 2 tracks. Track 1 is an audio file Track 2 is a lighting sequence with 3 steps.
Windows 10 x64, 8gb RAM, Core 2 Duo 2.6Ghz
QLC+_4.12.5.137
I'm using this version because of the issue of not being able to play WAV files in the official released version.
Faulting application name: qlcplus.exe, version: 0.0.0.0, time stamp: 0x621b535b
Faulting module name: qlcplusengine.dll, version: 0.0.0.0, time stamp: 0x621b50c8
Exception code: 0xc0000005
Fault offset: 0x000c50ef
Faulting process id: 0x1644
Faulting application start time: 0x01d82f4aa19d87c4
Faulting application path: C:\QLC+\qlcplus.exe
Faulting module path: C:\QLC+\qlcplusengine.dll
Report Id: 54541069-2d1d-4a07-8161-57147ad6ae84
Faulting package full name:
Faulting package-relative application ID:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2022-03-04T02:46:53.6220235Z" />
<EventRecordID>3985</EventRecordID>
<Correlation />
<Computer>Lights3-PC</Computer>
<Security />
</System>
- <EventData>
<Data>621b535b</Data>
<Data>621b50c8</Data>
<Data>000c50ef</Data>
<Data>1644</Data>
<Data>01d82f4aa19d87c4</Data>
<Data>54541069-2d1d-4a07-8161-57147ad6ae84</Data>
<Data />
<Data />
</EventData>
</Event>
Laurijn
hello i have trouble shoot many thing i dont use gif file anymore
and software is also bucky
al my resources are under 40% cpu and 50% ram 8gb it is not termal troteling
is it posible that the softwarre is locker at some gb of ram its is not peaking and constantly stable
kenact
kenact wrote: Fri Mar 04, 2022 4:09 am I also had a crash. My operator had just click Next in a chase. It was step 25 in the chase, which is a simple Show cue with 2 tracks. Track 1 is an audio file Track 2 is a lighting sequence with 3 steps.
We ran the same show last night, but restarted the laptop just before opening the house. There were no problems. I will continue doing that for the remainder of the run of this play.
The day the crash occurred, I had the laptop (Dell Latitude D630) running for several hours prior to the show, editing various Shows and Chases, and testing them. It was the application that crashed. The laptop continued to run. There were no other foreground applications running. The laptop was not online at the time of the crash, though it had been earlier.
There's nothing special about this QWX. Enttec OpenDMX, 12 generic dimmers, 2 Mega PAR Profile Plus, 1 loop back, only used to fade Preshow and Intermission music (not engaged when the crash occurred), four scenes used in main Chase (Preshow, Intermission, Blackout & General Wash) and 13 Shows. There are several functions defined, which are not used. 8 sound cue buttons on the desktop.
Mortimer.qxw
(87.78 KiB) Downloaded 208 times
keukenrol
Experiencing similar issue on desktop w10 x64. Freshly installed QLC+ 4.12.5, opening a certain showfile always gives me a C:\QLC+\qlcplusengine.dll crash. The same showfile on a laptop running the same QLC version and same Windows version never crashes.
Sp4rKy
Got the very same experience with 4.12.6 and .5. When opening a specific showfile qlcplus crash.
I first gave qlcplus5 a try and uninstalled it on the same computer, not sure it can be linked.
Sp4rKy
Sooo, after a few more tests / uninstall / cleaning in registry, I finally decided to edit my show file by hand, and removing the input plugin blocks (had one midi input, one dmx output and one midi feedback) did the trick. These devices are not connected to the computer I'm working with atm. Hope it can help
