QLC+ 4.12.1 release
QLC+ 4.12.1 is here to resolve some bugs and regressions introduced by 4.12.0.
As kind of expected, 4.12.0 has been a quite big and invasive release which required tests from a larger user base.
There are more things to be improved, so a 4.12.2 will be issued as well.
The most visible change in this version is a simplified Cue List widget for cross fading. See this for more info.
Changelog:
  • engine/RGBMatrix: fix crash when a fixture group has out of bounds heads
  • engine/EFX: fix crash when previewing a cloned EFX
  • engine: fix stop all with fade out time
  • Simple Desk: fix wrong channel offset set and reset
  • Virtual Console/Slider: fix Click & Go not applied to channels
  • Virtual Console/Frame: fix geometry after move in collapsed state
  • virtual Console/Cue List: simplified side faders with a single always blended fader
  • virtual Console/Cue List: fix behavior of side fader in steps mode
  • New fixture: American DJ FREQ Matrix Quad (thanks to Rasmus Ahlberg)
  • New fixture: Pro-Lights SunPix 12TRI (thanks to Lorenzo Andreani)
  • New fixture: GTD LM150 Spot (thanks to Pablo Martin Marrone)
  • New fixture: Chauvet SlimPAR Q12 USB (thanks to Ham Sadler)
  • New fixtures: American DJ Mega Bar RGBA, UKing PAR 36 (thanks to Gary M)
  • New fixture: Generic RGBW (thanks to Giacomo Gorini)
  • New fixtures: Lixada Triangle Spider Beam, Mini Gobo Moving Head (thanks to Daniel)
  • New fixture: Chauvet Ovation E-910FC (thanks to David Hay)
  • New fixtures: Ayrton MagicPanel 602, MagicBlade R (thanks to Baptiste Moinereau)
  • New fixture: American DJ Saber Spot RGBW (thanks to Mark Sy)
  • New fixture: Pulse Impstar 40 (thanks to Paul Wilton)
  • New fixture: American DJ WiFLY Chameleon (thanks to Jason R Johnston)
  • New fixtures: Chauvet COLORstrip Mini FX, Stage Right PAR StageLight 12Wx7 LED (thanks to John Thomas)
  • New fixture: Expolite AkkuLED Power Compact (thanks to Matthias Schlecht)
  • New fixture: Fun Generation PicoSpot 20 (thanks to Timo Willemsen)
  • New fixture: Litecraft Mini PAR AT10 (thanks to BuiDH)
  • New fixture: Ayra IntenZ CB-150 (thanks to Edgar Aichinger)
  • New fixture: American DJ UB 6H (thanks to Tom Costers)
  • New fixture: beamZ Lucid 1.2 (thanks to Owen Ling)
  • New fixture: Chauvet Intimidator Barrel 300 (thanks to Justin Hornsby)
  • New fixture: Briteq BT-575W (thanks to Carlos)
  • New fixture: Eurolite LED TMH-46 (thanks to Jakob Frank)
  • New fixture: Expolite TourLED MC180 (thanks to Luke Bonett)
  • New fixture: Chauvet COLORado 2 Quad Zoom (thanks to Neil Queripel)
  • New fixture: Chauvet Intimidator Spot 155 (thanks to Robert Scheffler)
Thanks again for your time and effort.
It seems that multithreading was a small step but a huge leap into the future.
Jungle Jim
Huge thanks!
cyclooctane
Huge thanks from me as well
thomasp
Real Name: Thomas P
Hey Massimo,
Thanks so much for the fixes and changes to the cue list. Works superb. Really appreciate what you do.
Regards, Thomas
vector
Real Name: Mark Sy
Excellent stuff Massimo
sandinak
Real Name: Branson Matheson
So this release is very stable .. using it in production and hasn't crashed or failed once. Thanks so much for the hard work ;)
MiGFulcrum
Real Name: Olivier Vandebroucke
THanks for the latest release! I've started using QLC+ in January and had slight instability issues sometimes that resulted in crashes (it was only once or twice, and it might have been because I've got a prehistoric computer that was running something else at the same time), but now it runs as smoothly as my laptop lets it run.
