Norman689
- Real Name: Norman Walker
i am not getting any dmx input with 4.12.0 . i am able to step back to 4.11.2 and all works fine .
Norman689
all work fine with 4.11.1
i do notice that i need to reboot the computer after trying 4.12 though , else 4.11.1 will not accept any dmx in .
Norman689
sorry . not thinking .
iOS - Windows 10 Home / version 1709 / build 16299.248 / Toshiba PC Satellite L745D
Interface - ArtNet Node 4 / GTS Elektronics
So is this related to the ArtNet plugin or other ?
Norman689
remu
- Real Name: Daniele
I'm considering to by GTS node4 adapter. Did you solved the problem? Is this adapter working fine or is better not to buy it?
Daniele
