When I try to import .d4 fixtures editor adds only first capability/function.
It seems that it was broken between versions 4.10.1 and 4.10.2
In version 4.10.1 editor import all capabilities, but in 4.10.2 and newer - only first one.
Avolites .d4 fixture profiles not importing correctly
Hi, I checked, and between 4.10.1 and 4.10.2 there's been a big switch concerning XML files.
Most likely D4 importer has not been tested properly. My bad. This should be trivial to fix though.
Can you please share the file you're trying to import, so that I can see the same thing you see ? Thanks
Sorry for late answer.
When I discover that import works with editor from older than 4.10.1 versions I tried with several files from avo d4 library.
E.g Involight LED MH1083W
- Involight_LED MH1083W.7z
- (2.29 KiB) Downloaded 416 times
Fixed, thanks for reporting.
You can find the fix in one of the latest test builds.
