Hi!
I've got several projects with many solo frames, and only now I doscovered that normal frames don't have this behaviour: when I minimize a solo frame then only the frame is minimized, but the whole content is still visible. Normal frames hide their content when they are minimized.
You can image there's will be many buttons on my Web-UI, just too many, as a lot of them just cover the ones that are below them. So till now I used QLC+ only on the main program, but it would be very very important for me to be able to use the Web-UI as well.
QLC version is 4.11 (= the actual one), but problem was there with the previous versions as well.
Thanky for your help!
Andreas
Minimized solo frames don't hide content
Your report is incomplete, since normal frames were collapsing correctly.
The issue was only in solo frames, and it is fixed now on GIT.
Since you haven't stated which OS you're using (see forum rules), I cannot point you to a test version to double check the issue is gone.
A Windows test build is available here.
For an updated RPi image you need to wait a bit. I'm finalizing a few things.
